ehlersgrub123
Feb 03, 2018Tutor
No internet output
I have a nighthawk X6 router. If I connect with a LAN to the internet modem I get good wifi and internet. If I connect the internet modem to a Netgear FS105 and then connect a LAN to the router I g...
- Feb 04, 2018
Too bad it has to work that way. Looks like I will have to run two cables from the basement to the router which will be on the second floor. One for input to the router and one back to the switch. But, thanks again.
ehlersgrub123
Feb 03, 2018Tutor
OK. Sorry for the loose terms. I have an FS105 switch connected to an fiber optic modem ( where the internet comes into my house) via an ethernet cable. Also connected to the FS105 via separate ethernet cables are a desktop computer and the Nighthawk X6 AC3000 router. I have very good internet conectivity on the desktop. I had wifi signal connection from the laptop to the router but no wifi internet service . Now I must state that after messing around for about an hour and getting no internet through the wifi I made my first post. Well, lo and behold, it somehow is now working. Is it possible that the "slow" characteristics of the FS105 made it take so long for the router to recognize the internet signal? The reason I have the FS105 between the modem and the router is that my desktop computer, printer, smart TV are all in the basement and I want the router on the second floor to get good wifi coverage outside the house and to a shop a couple hundred feet from the house where one of my laptops will be located. I'm guessing I should have gotten the GS105 instead. Thanks again.
antinode
Feb 03, 2018Guru
> [...] I have an FS105 switch connected to an fiber optic modem ( where
Is the (unspecified) "fiber optic modem" also a router? If not, then
connecting a switch to it might be very unwise. If so, then you may
have problems in some cases from cascading the two routers.
> [...] Is it possible that the "slow" characteristics of the FS105 made
Probably not, but any change in the wiring could confuse some
devices, especially when two routers are involved.
It would be more appropriate for the devices with gigabit ports.
> [...] The reason I have the FS105 between the modem and the router is
> I want the router on the second floor [...]
If the "fiber optic modem" is also a router, then it might make some
sense to configure the R7900 as a wireless access point. That would put
everything on one big LAN, which would eliminate any two-router
problems. Visit http://netgear.com/support , put in your model number,
and look for Documentation. Get the User Manual. Look for "Use the
Router as a Wireless Access Point".
- TerryPhFeb 03, 2018Virtuoso
Router as a Wireless Access Point".This is in my opinion, the best approach for your big houre.
- ehlersgrub123Feb 04, 2018Tutor
Updates. The modem is not a router. Another interesting thing I discovered. If the ethernet cable from the FS105 to the router is pluged into one of the four output ports of the router I can get internet wifi but if I plug it into the yellow Internet port I get nothing. If I connect the modem directly to the routers yellow port via an ethernet cable everything works fine.
- schumakuFeb 04, 2018Guru - Experienced User
All your systems must resde on the LAN/WLAN side of your router. Direct conections to the "Internet" as you have done using the switch on the Internet or WAN side are in general limited, the ISP only assing one (or very few) public IP addresses - to use on a single router typically.
The data path must be:
FTTH---Modem---WAN-port---Router---WiFiLAN-ports---Switch---otherSystems
