TerryJColes
Jul 18, 2019Luminary
No Internet over Ethernet Connections
My desktop computer is connected to the D7800 using Cat 5 direct to an Ethernet port. Yesterday afternoon I found that I couldn't reach the Internet or anything else on my network. After a fair bit ...
- Jul 18, 2019
Removingf the PoE Adaptors didn't help, but a Factory Reset seems to have fixed it (se far). I'll be back if the fault returns in a day or two.
If it doesn't, I'll mark this Topic as solved.
Jul 18, 2019Guru - Experienced User
If these issues arose after after a firmware update there's a few things you can try.
Whenever I do a firmware update, I make sure to do it over an ethernet connection and I do a full factory reset afterward. (a backup is nice for restoring purposes) If you didn't do the update over a hardwired connection, I would recommend doing so and performing the factory reset.
the other option is to downgrade the firmware. Not always the best option as firmware updates usually have benefits. But with that said, some firmwares have had issues and required people to downgrade before.
If you leave the power injector out of the loop, do you still have the issues? I've had them go bad before and create problems.
- TerryJColesJul 18, 2019Luminary
Thanks for the suggestions.
The update was done by my son who uses a WiFi connection. I would consider re-applying it, but I no longer have a wired connection!
I must admit, I was under the misapprehension that doing a Factory Reset would restore the firmware to the 'factory' state, but clearly not. It will clear all the settings though, so I'd better get a good record of what they are!
I'm not in a position to try disconnecting the PoE devices ATM, but I'll try it and report back later.
- plemansJul 18, 2019Guru - Experienced UserGlad to hear it! Hopefully it stays working!
