TerryJColes's avatar
TerryJColes
Luminary
Jul 18, 2019
No Internet over Ethernet Connections
My desktop computer is connected to the D7800 using Cat 5 direct to an Ethernet port. Yesterday afternoon I found that I couldn't reach the Internet or anything else on my network.  After a fair bit ...
  • TerryJColes's avatar
    TerryJColes
    Jul 18, 2019
    Removingf the PoE Adaptors didn't help, but a Factory Reset seems to have fixed it (se far).  I'll be back if the fault returns in a day or two.
    If it doesn't, I'll mark this Topic as solved.
