ASG2001
Jun 01, 2023Follower
No internet R7800
I have been using a nighthawk R7800 since October 2022. Now it suddenly gives the message no internet. I've turned it on/off, unplugged it, and reset it, but the problem persists. All lights are burni...
Jun 01, 2023Guru - Experienced User
Like michaelkenward says, the key is what its connecting to.
What gateway is it?
did you try replacing the cable between the 2?
Or checking to see if that gateway is setup properly?
