Jacqub52
Jun 30, 2022Follower
No internet to router.
My PC died..so I bought a new one. The new one is wireless, the old one wasn't. So now I want to connect my modem to the router and away we go right? Not so fast....according to tutorial..Connect Et...
Jun 30, 2022Guru - Experienced User
You gave us nothing to go off.
There a NG product your referring too?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
