Jeff_Clarke
Sep 14, 2021Aspirant
No internet via 5G
Searched around and my issue seems to be very similar to others reported. I have had this router config for at least two years now with no issues. Yesterday, all of the sudden my 5G wireless ...
Sep 14, 2021Guru - Experienced User
Factory reset the router by pressing the reset button for 10 seconds then release. Power OFF the router fully for 1 minute then back ON. Walk thru the setup wizard. Check the 5Ghz radio...
Jeff_Clarke
I did factory reset even though I should not have to do that..... still have same issue
Seems one of the radios but have died..... used same SSID on second one and it works fine.
Yes there are and have been a lot of changes in IT....some good, some bad. The development of cheap hardware/software is not always what it is cracked up to be because to make it cheap they cut corners.
If a vendor was in my office and said that to me I would toss him out and never buy from him ever again.
Oh well....onto the next issue for me.
Done with this one.
