fredbaker
Dec 17, 2021Aspirant
No internet without bridge
Hello, My previous setup of Motorla modem >> Ooma Hub >> R7000P worked fine for years, but after the Ooma Hub's recent death and rewiring the modem's output straight into the router, no internet ...
- Dec 17, 2021
Has a power off for 1 minute then back ON with the ISP modem and router?
Turn off and unplug modem.
Turn on computers and rest of network.
Dec 17, 2021Guru - Experienced User
- fredbakerDec 17, 2021Aspirant
My modem is Arris SURFboard SB6141
Since there is no wifi in my house, I can't log into my Netgear software, so I don't know the firmware version. Is there another way to log in?
- FURRYe38Dec 17, 2021Guru - Experienced User
Turn on computers and rest of network.- fredbakerDec 17, 2021Aspirant
I did that several times already with the same result. I just did it again, same thing.
However this last time I noticed an ethernet cable was plugged in the back of the router that wasn't connected to anything (the previous computer was pulled out some time ago). So I removed that and rebooted again and this time it worked. I have no idea why that would have made a difference, but it's working now and I'm not touching anything.
Thanks for your help.
