fredbaker
Dec 17, 2021Aspirant
No internet without bridge
Hello, My previous setup of Motorla modem >> Ooma Hub >> R7000P worked fine for years, but after the Ooma Hub's recent death and rewiring the modem's output straight into the router, no internet ...
- Dec 17, 2021
Has a power off for 1 minute then back ON with the ISP modem and router?
Turn off and unplug modem.
Turn on computers and rest of network.
fredbaker
My modem is Arris SURFboard SB6141
Since there is no wifi in my house, I can't log into my Netgear software, so I don't know the firmware version. Is there another way to log in?
Dec 17, 2021Guru - Experienced User
- fredbakerDec 17, 2021Aspirant
I did that several times already with the same result. I just did it again, same thing.
However this last time I noticed an ethernet cable was plugged in the back of the router that wasn't connected to anything (the previous computer was pulled out some time ago). So I removed that and rebooted again and this time it worked. I have no idea why that would have made a difference, but it's working now and I'm not touching anything.
Thanks for your help.
- FURRYe38Dec 17, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. š”
