akonieczka
Jul 25, 2019Aspirant
No IP address being assigned to device
I am attempting to connect a new device to the router via wifi. The device is not functioning properly (no internet access). In the list of attached devices, it shows up but with no IP address assign...
- Jul 26, 2019
Turned out to be the security options after all. WPA2 does not work but WPA does. I had tried earlier removing security altogether but at that time was connecting via 5GHz which found out doesn't work. So the winning combo is 2.4GHz with WPA.
myersw
Jul 25, 2019Master
Would be helpful for trouble indentification if you would tell us what the device is? Yes if it supports dhcp it should get an address.
akonieczka
Basement Watchdog Connect Wi-Fi Module
