LuckyH's avatar
LuckyH
No lights on the back of the router.
Hi Guys, I recently purchessed the R8000. All is working fine, All the lights on front are ok and all white. It's kind of supid question I have, Probably not SO stupid.! So...My modem has a light...
  • VE6CGX's avatar
    Jun 02, 2016
    Just turn back on the PC and see what happens to the light on the router.  When you shut down PC. It is not completely turned off as you can see the light on the RJ45 connector. Nothing to worry or think about.
