orbeavhawk
Oct 21, 2021Aspirant
No Longer able to access my Router Software?
Please advise - now when I enter www.modemrouter.net in URL - it sends me to some NNetgear Page/site and does nof give me access to software for my router, is there some other way? TKS
- Oct 22, 2021Try using your default gateway address to access it
Oct 22, 2021Guru - Experienced User
Try using the ip address of the router.
The default is 192.168.1.1
It could have changed if you're in a double nat.
What gateway do you have?
- orbeavhawkOct 22, 2021Aspirant
TKS for response!
I used "ipconfig" to get info for you:
IPv4 Address: 192.168.0.18
Default Gateway: 192.168.0.1
- plemansOct 22, 2021Guru - Experienced UserTry using your default gateway address to access it
Thank YOU - that did it!
