securesearcher
May 09, 2020Aspirant
No longer can add/edit static IP address
The DHCP option on my router is enabled. I also maintain a list with ~50 static IP addresses. The other day I updated the firmware from v2 to the latest of v3 V1.0.4.84_10.0.58 through the built-in "...
- May 17, 2020
Problem has been resolved by resetting the router. https://www.router-reset.com/info/Netgear/R6700
I figured out the model of my hardware. There is a label at the bottom which indicates it is R6700v3. I tried with older firmware for v3 with no luck. Finally, I decided to reset it and that worked. Now I can add and modify static IP addresses in the address reservation table under Advanced -> Setup -> LAN Setup.
Thank you everyone for providing help.
securesearcher
May 10, 2020Aspirant
Thanks for your reply.
> Assuming that you're referring to the ADVANCED > Setup > LAN Setup :
Address Reservation table, then those are reserved dynamic addresses,
not "static" addresses (which would be configured on the devices
themselves, not on the (DHCP server on the) router).
Correct. I have all the IP addresses statically assigned on the actual devices.
> You tried to load some version of R6700v2 firmware into an R6700v3
(with its different hardware)? I'd expect that to fail.
I can't tell if my hardware device is v2 or v3. I bought it in 2019 and back then it was showing v1. I kept it up to date with the built-in check/update functions and ended up now with v3 firmware. Still unsure if that's the correct firmware for the hardware I own, but I believe negear have all their checks in place before they roll out a specific firmware version. Am I missing anything here?
> Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads.
Did that, but haven't checked out the "View Previous Versions"
Thank you! Appreciate your help.
antinode
May 10, 2020Guru
> [...] I have all the IP addresses statically assigned on the actual
> devices. [...]
> [...] I know there is a limit of 64 static IP addresses, [...]
How, exactly, do you "know" that? I'd expect the router to have a
limit on reserved (dynamic) addresses (the list of which it maintains).
Why it would care about static addresses (configured elsewhere) is a
mystery to me.
> [...] I also maintain a list with ~50 static IP addresses. [...]
Where/how, exactly, do you "maintain" this list?
> The DHCP option on my router is enabled. [...]
What is the address range of your DHCP pool? Are your ~50 static IP
addresses" in that pool? (Which would not be a good idea.)
> I can't tell if my hardware device is v2 or v3. [...]
Look for "Model" on the product label? As a clue, downloading
firmware kits for the various hardware varients shows which file type is
used for which model (hardware variant):
R6700-V1.0.2.8_10.0.53.chk
R6700v2-V1.2.0.62_1.0.1.img
R6700v3-V1.0.4.84_10.0.58.chk
> [...] I bought it in 2019 and back then it was showing v1. [...]
"showing" what, exactly, where, exactly? Clearly, the currently
loaded firmware is for an R6700v3.
> [...] I believe negear have all their checks in place [...]
I wouldn't trust Netgear's firmware distribution scheme for much, but
I haven't seen any reports here about a router automatically updating
anything with firmware for the wrong device.
If you have managed to load some inappropriate firmware image onto
the thing, then that might explain many problems.
- securesearcherMay 17, 2020Aspirant
