robkayakmobile
Sep 01, 2021Aspirant
No LTE 4G Netgear Nighthawk M1 ATT Prepaid
Purchased through Amazon Netgear seller.
With AT&T I am only able to connect with WCDMA (H and H+).
I have long discussions with AT&T still no resolution.
Using cellmapper.com I located two dedicated ATT cell towers.
Tower 1
Bands 2,12,14
and...
Tower 2
Bands
2,12,14,30,66
The device was set at Cellular --> LTE All
At each tower... I turned off the device, and turned back on.
I drove around the towers to be sure to get any possible cell locked in.
No LTE 4G...
I even replaced the SIM, which was the "only" solution that I have found to resolve the issue.
As a test that the device could get a real LTE (not H and H+)...
I got a pre paid data only from T-Mobile...
Immediately it connected to LTE,
Why can I not connect to AT&T "real" LTE ??
The Nighthawk M1 is the same as sold at AT&T store/website....
The only difference between "their" device and the Amazon Netgear device would be some firmware blocking me access to there LTE network ?
Are these Amazon Negear Nighthawks not compatible with AT&T 4G LTE ?
I have had the unit for a month... tried everything I know.
MIght have better luck in the mobile router forum and not the general home router forum.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
- robkayakmobileAspirant
Moderators please delete as I put this in the above mentioned location for better responses.
at
apologies for the double posting.
