rudiklein
Dec 17, 2017Star
No more 2.4 Wifi on R7000 Nighthawk after V1.0.9.14_1.2.25 update
Hi, Never had an issue before with the R7000, but after the V1.0.9.14_1.2.25 update I have no wireless 2.4Ghz devices connected to the router. 5Ghz works fine, but most of my devices do not suppo...
- Dec 18, 2017
rudiklein wrote:
But honestly, a factory reset sounds like an advice from Microsoft on Windows.
Yes, it does, but it's well documented on this forum that certain firmware updates are incompatible with the settings from previous versions. Chalk it up to Netgear's unwillingness to fix their configuration subsystem to be backwards and forwards compatible.
rudiklein
Dec 17, 2017Star
Some additional information:
The 2.4 SSID is visible and when you attempt to connect to it, it takes along time, then fails.
From an Android devices it failes with "unable to obtain IP address"
From W10 it connects after a while, but "with no internet, secured"
- rudikleinDec 17, 2017Star
Interesting news. (sorry I haven't tested this before I started the initial post, but people were working on the network and I didn't want to interfer).
After disabling/enabling the 2.4 radio, all WiFi devices connected without any problem.
So, no downgrade, just radio on/off/on.
Maybe I am now part of the group of R7000 owners that have intermittent problems :-)
Anyway, I'm happy for now. Let's see what happens in the next few days.
