rudiklein
Dec 17, 2017Star
No more 2.4 Wifi on R7000 Nighthawk after V1.0.9.14_1.2.25 update
Hi, Never had an issue before with the R7000, but after the V1.0.9.14_1.2.25 update I have no wireless 2.4Ghz devices connected to the router. 5Ghz works fine, but most of my devices do not suppo...
- Dec 18, 2017
rudiklein wrote:
But honestly, a factory reset sounds like an advice from Microsoft on Windows.
Yes, it does, but it's well documented on this forum that certain firmware updates are incompatible with the settings from previous versions. Chalk it up to Netgear's unwillingness to fix their configuration subsystem to be backwards and forwards compatible.
candroulakis
Dec 17, 2017Aspirant
Following this as mine is not completely out but fails daily needing a reset to bring it back up.
TheEther
Dec 17, 2017Guru
There seem to be a lot of reports of problems with the latest version. Have you tried performing a factory reset? Every once in a while a new firmware update requires it. And don't restore settings from a backup. That'll only undo the factory reset. You need to reconfigure everything by hand.
