rudiklein
Dec 17, 2017Star
No more 2.4 Wifi on R7000 Nighthawk after V1.0.9.14_1.2.25 update
Hi, Never had an issue before with the R7000, but after the V1.0.9.14_1.2.25 update I have no wireless 2.4Ghz devices connected to the router. 5Ghz works fine, but most of my devices do not suppo...
- Dec 18, 2017
rudiklein wrote:
But honestly, a factory reset sounds like an advice from Microsoft on Windows.
Yes, it does, but it's well documented on this forum that certain firmware updates are incompatible with the settings from previous versions. Chalk it up to Netgear's unwillingness to fix their configuration subsystem to be backwards and forwards compatible.
rudiklein
Dec 18, 2017Star
Everybody, thanks for the help.
It is what it is: bad design is the cause, factory reset the solution.
(The downgrade didn't help, but you probably guessed that already.)
I'll have some typing to do tonight.....
Bye,
Rudi
JamesGL
Dec 18, 2017NETGEAR Employee Retired
Hi Mprinter17,
Thank you for feedback. To help us easily monitor issues related to the latest firmware, please post it under the thread below.
- benasaurDec 19, 2017Aspirant
I want to also confirm that V1.0.9.14_1.2.25 doesn't fix the 2.4ghz drop issue. Started experiencing this sometime in November, not sure exactly when because router is configured to automatically install updates. 2.4g has never been stable since, requires power cycle, finally tried hardware reset and it dropped again after ~12 hours of use.
Can anyone confirm a last known good firmware version? I've read 1.0.7.12. Are there any others you have reverted to and has worked well?
- rudikleinDec 20, 2017Star
Please keep in mind that downgrading could make you vulnerable to other issues and may cause a security weakness.
Then you might have 2.4Ghz working, but you also might get unwanted visitors.
Just saying.
Rudi
- user05Dec 20, 2017Guide
I updated from v1.0.7.10_1.2.3 to v1.0.9.14_1.2.25. One of my 2.4 GHz wi-fi devices started to be disconnected.
I downgraded back to v1.0.7.10_1.2.3, made a hard reset and restored my saved settings (from 1.0.7.10_1.2.3).
So far NO problems with 2.4 GHz (2 days non-stop usage/monitoring)!
