rudiklein
Dec 17, 2017Star
No more 2.4 Wifi on R7000 Nighthawk after V1.0.9.14_1.2.25 update
Hi, Never had an issue before with the R7000, but after the V1.0.9.14_1.2.25 update I have no wireless 2.4Ghz devices connected to the router. 5Ghz works fine, but most of my devices do not suppo...
- Dec 18, 2017
rudiklein wrote:
But honestly, a factory reset sounds like an advice from Microsoft on Windows.
Yes, it does, but it's well documented on this forum that certain firmware updates are incompatible with the settings from previous versions. Chalk it up to Netgear's unwillingness to fix their configuration subsystem to be backwards and forwards compatible.
benasaur
Dec 19, 2017Aspirant
Can anyone confirm a last known good firmware version? I've read 1.0.7.12. Are there any others you have reverted to and has worked well?
rudiklein
Dec 20, 2017Star
Please keep in mind that downgrading could make you vulnerable to other issues and may cause a security weakness.
Then you might have 2.4Ghz working, but you also might get unwanted visitors.
Just saying.
Rudi
