Rafjel
Jun 18, 2021Aspirant
"No new firmware version available" for R7000 AC1900 when checking via router?
How does it come that I don't get recent firmware updates when checking via the router (actual v1.0.9.88), although there are new ones on the download page of Support (most recent 1.0.11.123 - Hot Fi...
- Jun 26, 2021
Meanwhile I've downloaded and installed the latest firmware manually without any problem at execution time and when starting up the router.
michaelkenward
Jun 19, 2021Guru - Experienced User
Rafjel wrote:
How does it come that I don't get recent firmware updates when checking via the router (actual v1.0.9.88), although there are new ones on the download page of Support (most recent 1.0.11.123 - Hot Fix)?
New firmware takes time to migrate to the FTP server that feeds the on-board check. It usually arrives first on the support pages and then the FTP server, although it sometimes happens the other way round.
You can think of a hot fix as a beta version that has not been through all of the testing needed for an "official" release. That can change and may never show up on the FTP server.
