crowella
Jan 22, 2022Aspirant
no product label netgear modem/router c6300
Help! i purchased netgear modem router from fb marketplace. It came in a different box that what it actually looks like and the modem itself does not have a product label. the label on the box is ...
crowella
Jan 23, 2022Aspirant
How do I log into it? I can’t seem to get it connected to my existing wifi
Jan 23, 2022Guru - Experienced User
Factory reset the whatever device it is. Push and hold reset for 7-15 seconds while powered on. that'll get you back to the defaults.
Then hardwire a pc/laptop into the modem/router (whatever). You can try accessing it that router.
the default login is: admin
default password: password
all lower case.
that'll get you into the gui through the browser. From there, if its a modem/router combo device, you could setup your wifi details.
- crowellaJan 23, 2022AspirantI tried to do that, Ethernet from laptop to modem router but not sure what I’m doing wrong the modem router says it’s not connected via wifi
- plemansJan 23, 2022Guru - Experienced User
crowella wrote:
I tried to do that, Ethernet from laptop to modem router but not sure what I’m doing wrong the modem router says it’s not connected via wifiwhy would it say its connected via wifi if you're hardwiring a laptop in?
Do you got a picture of the back of the device (and the device itself) so we can at least determine if its a modem or a modem/router combo device?
that'll tell us the proper address to access it with.
modem only: 192.168.100.1
modem/router: 192.168.1.1 (default) some are on 192.168.0.1 (depending on your isp)
my xfinity modem router i rent is currently connected thats how im accessing my wifi.
the netgear modem/router is plugged in and ethernet from laptop to modem. when I try to log in it says its not connected to wifi, how do i connect it to my existing wifi to be able to log into it?
