Gaspard-Arnaud
Jan 06, 2021Aspirant
No WIFI and no access to router
Hello, I tried to acces to router by normal procedure (www.routerlogin.net) but I was redirected to your site pages. Then I decided to download your app on my phone trying to find a way to block...
Jan 06, 2021Guru - Experienced User
1. what router do you have? you put a7000 in the signature which is a usb wireless adapter.
2. what firmware is on it?
3. what modem/gateway is it connected to?
antinode
Jan 06, 2021Guru
> [...] I was redirected to your site pages.
Not _my_ "site pages". Not a useful description.
> ( the firmware is at the last version)
As always, an actual version number would be more useful than your
opinion of what's "last" today.
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Not a router. Look for "Model" on the product label. Connected to
what?
Possibly relevant:
- dingodawgJan 07, 2021Aspirant
u have a patter of not being helpful, maybe time for you to stop. there are nicer and more effective approaches than yours for sure.
- Gaspard-ArnaudJan 07, 2021Aspirant
Thank's at alls for your kind replies :
1 - I understand I was not precise but I am a newcomer and not a computer nerd
2 - Sorry for my late response, beeing in europe, I took time to sleep !
....Then details
Configuration :
- Nighthawk AC1900 Smart WiFi Router(R7000) S/N 445D7B7WA10A1 was used in conjunction with a modem/router (internet box : "freebox revolution") > the device is only used for wifi
- Firmware version 1.0.9.88
Here are explanations:
A. Good news : WIFI problem is fixed:
- by taking the Netgear WIFI/Router on my hand I disconnected WIFI, one of my finger pushing unfortunately the WIFI button to off.
B. Acces to Nighthawk AC1900 Smart WiFi Router(R7000)
- My question is the same : I can't access to the device by www.routerlogin.net, www.routerlogin.com or by 192.168.1.1 or 192.168.0.1
I saw in one of post than it could come from browser (mine is firefox) by "using DNS over http". How could I verify this . Is there any other solution ?
Thank' again
Thank's for your help
Finaly, problem acces solved : to log in I used the IP adress given by the Android Nighthawk apps.
But I am ashtonised by documentation. The userguide dont speak about this problem. How can we identifiy the IP adress without the Android application ( application wich was not available when I bought the product) ? Does it mean I will have to identify the iP adress each time I will have to login ?
