nyvagenealogy
Jun 16, 2021Aspirant
no wifi connection
nighthawk r6400v2 1. no wifi can connect via ethernet cable BUT NO WIFI can not connect table or laptop via wifi 2. bought a brand new netgear to fix #1 it had NO INTERNET AND N...
- Jun 17, 2021
> the cox cable guy came in and pushed the ON wifi button, that i did
> not know was NOT A LIGHT, but a button that lights up> [...] Get the User Manual (at least). Read. Look for the
> LED descriptions and "Troubleshoot". Pay particular attention to the
> "WiFi On/Off button with LED". Did you press it? Further reading
> might not hurt, either.It's a miracle! Who'd've guessed?
antinode
Jun 16, 2021Guru
> nighthawk r6400v2
Firmware version? Connected to what?
> laptop via wifi
"can not" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
The non-psychics in your audience might be unable to guess what it is
or what you did with it.
> it had NO INTERNET AND NO WIFI (ax1800)
"AX1800" is a speed, not a model number. Look for "Model" on the
product label. I'd guess that there's a User Manual for it, too.
> would someone PLEASE tell me what to do........
You might try this radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
> it's not their products.
Right. Wired-good, wireless-bad is a local-to-you problem.
