nyvagenealogy's avatar
Jun 16, 2021
no wifi connection
nighthawk r6400v2   1. no wifi   can connect via ethernet cable BUT NO WIFI can not connect table or laptop via wifi     2. bought a brand new netgear to fix #1     it had NO INTERNET AND N...
  • antinode's avatar
    antinode
    Jun 17, 2021
    > the cox cable guy came in and pushed the ON wifi button, that i did
    > not know was NOT A LIGHT, but a button that lights up
    > [...] Get the User Manual (at least).  Read.  Look for the
    > LED descriptions and "Troubleshoot".  Pay particular attention to the
    > "WiFi On/Off button with LED".  Did you press it?  Further reading
    > might not hurt, either.
       It's a miracle!  Who'd've guessed?
