twocharsLogs
Dec 26, 2023Aspirant
No Wifi on R9000
Hi, My friend bricked his R9000, so I unbricked it and seeing Netgear Genie page after connecting it to my laptop over LAN Cable. But I can't find the router over Wifi, I see default SSID and pas...
Dec 26, 2023Guru - Experienced User
Does it appear when you press the reset button in back for 15 seconds then release?
- twocharsLogsDec 26, 2023Aspirant
Doesn't appear even after a reset, tried it a few times.
Currently on FW 1.0.5.42.
- FURRYe38Dec 27, 2023Guru - Experienced User
Has any other FW like DD-WRT been loaded on this router?
Try a 30-30-30 reset on the router.
Also might try a TFTP re-load of the FW. Might try Voxels FW as well.
If these don't work, let me know, theres one last resort item to try.
- twocharsLogsJan 03, 2024Aspirant
Happy New year !!!
My friend did try to install DD-WRT but I'm not aware if that caused this issue in the first place, it was not successful based on the router's control panel being unavailable.
I tried 30-30-30 rest, there wasn't any change. So I moved to installing FW both Official and Voxel's, still no luck.
Let me know the last resort item, hope that works
