twocharsLogs
Dec 26, 2023Aspirant
No Wifi on R9000
Hi, My friend bricked his R9000, so I unbricked it and seeing Netgear Genie page after connecting it to my laptop over LAN Cable. But I can't find the router over Wifi, I see default SSID and pas...
Dec 26, 2023Guru - Experienced User
Does it appear when you press the reset button in back for 15 seconds then release?
twocharsLogs
Doesn't appear even after a reset, tried it a few times.
Currently on FW 1.0.5.42.
- FURRYe38Dec 27, 2023Guru - Experienced User
Has any other FW like DD-WRT been loaded on this router?
Try a 30-30-30 reset on the router.
Also might try a TFTP re-load of the FW. Might try Voxels FW as well.
If these don't work, let me know, theres one last resort item to try.
- twocharsLogsJan 03, 2024Aspirant
Happy New year !!!
My friend did try to install DD-WRT but I'm not aware if that caused this issue in the first place, it was not successful based on the router's control panel being unavailable.
I tried 30-30-30 rest, there wasn't any change. So I moved to installing FW both Official and Voxel's, still no luck.
Let me know the last resort item, hope that works
- michaelkenwardJan 03, 2024Guru - Experienced User
Sadly, they may have broken your router.
If you need to backtrack and restore the device to the Netgear firmware, you'll have to talk to the people who write DD-WRT. Netgear doesn't support that and can't/won't help.
