twocharsLogs
Dec 26, 2023Aspirant
No Wifi on R9000
Hi, My friend bricked his R9000, so I unbricked it and seeing Netgear Genie page after connecting it to my laptop over LAN Cable. But I can't find the router over Wifi, I see default SSID and pas...
twocharsLogs
Doesn't appear even after a reset, tried it a few times.
Currently on FW 1.0.5.42.
Dec 27, 2023Guru - Experienced User
Has any other FW like DD-WRT been loaded on this router?
Try a 30-30-30 reset on the router.
Also might try a TFTP re-load of the FW. Might try Voxels FW as well.
If these don't work, let me know, theres one last resort item to try.
- twocharsLogsJan 03, 2024Aspirant
Happy New year !!!
My friend did try to install DD-WRT but I'm not aware if that caused this issue in the first place, it was not successful based on the router's control panel being unavailable.
I tried 30-30-30 rest, there wasn't any change. So I moved to installing FW both Official and Voxel's, still no luck.
Let me know the last resort item, hope that works
- michaelkenwardJan 03, 2024Guru - Experienced User
Sadly, they may have broken your router.
If you need to backtrack and restore the device to the Netgear firmware, you'll have to talk to the people who write DD-WRT. Netgear doesn't support that and can't/won't help.
- FURRYe38Jan 03, 2024Guru - Experienced User
Ok, was hoping something would change that.
Last ditch effort here.
The R9000 and XR700 are same HW and code base. I had a XR700 that I bought off fleabay in hopes I could load NG stock FW. Ya, thought wrong. XR700 was busted after I loaded NG stock FW on it. Seems the DDWRT FW changes the NVram configurations around causing problems if NG stock FW is loaded. WIFI Radios were notworking among other things. I had no idea if I could get that fixed until I ran cross this gem:
After downgrading the FW and getting telnet running, I had the XR700 up and running with in minutes and wifi radios came back and working great. Thought I had a bad router that I paid too much for. All good now.
Let see if this helps your R9000. Load up NG stock FW and a old version that has telnet.
twocharsLogs wrote:
Happy New year !!!
- twocharsLogsJan 04, 2024Aspirant
I tried those commands over telnet but that did not help. I think the router is gone now, I'll hand over the router to my friend. Thanks for your support
