twocharsLogs
Dec 26, 2023Aspirant
No Wifi on R9000
Hi, My friend bricked his R9000, so I unbricked it and seeing Netgear Genie page after connecting it to my laptop over LAN Cable. But I can't find the router over Wifi, I see default SSID and pas...
Jan 04, 2024Guru - Experienced User
Might ask your friend to check out the resources mentioned over on smallnetbuilders forum where most of that data came from. Might someone there or something that get help with that. Could just a slight difference in commands too.
Good Luck.
twocharsLogs wrote:
I tried those commands over telnet but that did not help. I think the router is gone now, I'll hand over the router to my friend. Thanks for your support
twocharsLogs
Jan 12, 2024Aspirant
I'll check on smallnetbuilders, thanks for the inputs
