Mnmsprague1779's avatar
Jun 21, 2016
No wifi on the third floor
I just purchased a nighthawk r7000. My modem is currently located in the basement and the router is there too. I cannot bring it up to the main floor without re-wiring. What are my options to get wifi...
  • Retired_Member's avatar
    Retired_Member
    Jun 21, 2016
    You could try power line adapters. You'll never have decent thoughput.
