solidsnake1298's avatar
Apr 16, 2019
NOIP/DDNS update fails regularly
I've recently setup my R7000 to update to my ddns at noip.  While the update eventually succeeds, it ALWAYS fails a number of times before it succeeds.  Usually 3-5 failures before success.  Yesterda...
  • shadowsports's avatar
    shadowsports
    Apr 17, 2019
    I'm in the same boat as Kitsap .  Have been using NoIP with R7000, Orbi and R8000p for years.  Registration authenticates once every 24 hrs.  Never fails.
    Who is your ISP.  What device is in front of your Nighthawlk?
    More inclined to believe its your connection to the web.  But If its not your connection, you can also try changing your PW.  Try something simple, and see if that resolves the intermittent failures.
