solidsnake1298
Apr 16, 2019Aspirant
NOIP/DDNS update fails regularly
I've recently setup my R7000 to update to my ddns at noip. While the update eventually succeeds, it ALWAYS fails a number of times before it succeeds. Usually 3-5 failures before success. Yesterda...
- Apr 17, 2019
I'm in the same boat as Kitsap . Have been using NoIP with R7000, Orbi and R8000p for years. Registration authenticates once every 24 hrs. Never fails.
Who is your ISP. What device is in front of your Nighthawlk?
More inclined to believe its your connection to the web. But If its not your connection, you can also try changing your PW. Try something simple, and see if that resolves the intermittent failures.
shadowsports
Apr 17, 2019Hero
solidsnake1298
Apr 17, 2019Aspirant
Firmware - V1.0.9.64_10.2.64
ISP - Comcast (1000Mbps Down / 35Mbps Up)
Modem - Arris SB8200
Modem Firmware - SB8200.0200.174F.311915.NSH.RT.NA
I just logged into my NOIP account directly and it says it hasn't been updated since I created the ddns hostname. I should also point out that I have enabled IPV6 since the modem, router, and Comcast are fully IPV6 enabled. My score at https://test-ipv6.com/ is 10/10 for IPV6 readiness.
The type of DNS record at NOIP is just a type A. Is it possible that the R7000 is trying to push my IPV6 address to a type A instead of pushing my IPV4 address? Should I create a AAAA record and see what happens?
