BV72715
Nov 27, 2020Tutor
Non existent tech support
If you are lucky enough to get through,I did after 1hr+ wait time and receiving 3 different case numbers I was told they needed to escalate my case and would email me. The email I received said that ...
Nov 28, 2020Guru - Experienced User
Netgear phone support might not be the greatest (not the first report of this and won't be the last) Christian_R ChristineT
But we're willing to help you out on the community support forum. We're halfway reasonable at it :)
What router/device do you have?
What modem/gateway is it connected to?
What firmware is on it?
What issue (in detail since we aren't there) are you having with it?
- BV72715Nov 29, 2020Tutor
Thank you both for your kind offer to help but this has been such a bad experience I have bought a Synology RT2600ac and am going to return the Netgear router. I just can't see spending money with a company that doesn't seem to be interested in supporting their customers.
- plemansNov 29, 2020Guru - Experienced User
good luck! I've heard good things about the Synology RT2600AC but I haven't had the chance to use one myself.
I hope it works great for you!
Thanks! I've used them before for customers. They are super reliable and have loads of features. They are more expensive than Netgear but worth it in my opinion plus got this on sale for only $20 more than the Netgear router.
