Imran8553's avatar
Imran8553
Not able to access login page from primary network
Yesterday I have set up my netgear router as secondary network of home network. I have updated the IP address. Know when I try to connect to netgear router directly it is not able to connect to internet. I cant even access my netgear login page as whenever I try  to login 192.168.1.1 it goes to primary network router page. I tried several method and tried to login to nighthawk app but even it doesn't work; I need my netgear to contact internet without primary router. Any help will be appreciated. I configured home network by watcing this youtube video: https://youtu.be/lsE9OWQdtog
  • > [...] I have set up my netgear router as secondary network of home
    > network. [...]
       Why?  Is there some actual problem which you were trying to solve?
       What, exactly, does "secondary network" mean to you?
       What, exactly, did you connect to what, exactly?  (Hint: If a device
    has different types of Ethernet ports, then "connected to device" is not
    enough detail.)
    > [...] I have updated the IP address [...]
       _Which_ "the IP address"?  "updated" it to what?  How?  Why?
    > [...] primary network router [...]
       What is it?
    > [...] I tried several method [...]
       Think, for a moment, about how little useful information that
    non-description conveys to the non-psychics in your audience.
    > [...] I need my netgear to contact internet without primary router.
       I don't know what that means.
    > [...] I configured home network by watcing this youtube video: [...]
       I don't care what you watched.  What you _did_ is what matters, and
    no movie made by someone else will reveal that.
    > Model: R6120|AC1200 Dual Band WiFi Router
       If your goal was to use the R6120 to expand your wireless-network
    coverage, then:
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Use the Router as a WiFi Access Point Only".
    • Imran8553's avatar
      Imran8553
      I wnated to improve my range to terrace and configured netgear router as slave router from my primary router.
      I have 2 router. 1 is connected to INternet & from 1st router LAN i connect to netgear LAN port & its woking. But when I connect the internet cable directly to netgear it gives error as "Ethernet port has no valid IP config" "wifi has no valid ip config".
      It was shown in youtube video to update IP address as Static insted of dynamic to connect to 1st router. I remember the IP address but its not working now
        --  I need my netgear to contact internet without primary router.
      It means I need netgear router back to normal talking to internet without 1st router.
      • antinode's avatar
        antinode
        Guru
           Ok.  Aside from modern considerations of political correctness, the
        proper term for what you want is "wireless access point".  It won't
        really be a router any more, only a WAP.  (And "enslaved router" would
        not be an improvement.)
        > [...] when I connect the internet cable directly to netgear [...]
           Which part of the following was unclear?:
        > [...] (Hint: If a device has different types of Ethernet ports, then
        > "connected to device" is not enough detail.)
           What, exactly, does "the internet cable" mean to you?  A cable
        usually has two ends.  Where are the ends of that cable?
           > It was shown in youtube video to update IP address [...]
           A router like the R6120 has _two_ IP addresses, LAN and WAN/Internet.
        Hence:
        >    _Which_ "the IP address"?  [...]
           But let's forget that excursion.  What I'd do:
           1. Having fiddled with the R6120, it would probably be wise to do a
        settings reset on it before proceeding.
           2. Put your (unspecified) "primary router"/"1st router" back where it
        was, configured as it was originally.  When that's working properly
        again, follow the first suggestion:
           3. Do that.  No movie required, only RTFM.
           When you do that, the R6120-as-WAP should get a new LAN IP address
        (now, its only IP address) from your (unspecified) "primary router"/"1st
        router", using DHCP.  You'll probably need to look at some kind of
        "Attached Devices" or "DHCP clients" (or similar) report from that
        router to learn the new LAN IP address of the R6120-as-WAP.
           There should be a way to reserve an address, on the (DHCP server in
        the) "primary router", for the R6120-as-WAP.  If you choose something
        memorable, then you won't need to look it up every time you want to talk
        to the managemant web site on the R6120-as-WAP.  (The usual
        "routerlogin" names may or may not work to find it, depending on where
        your web-browsing computer is connected, but its (new) LAN IP address
        should work from anyplace on your LAN.)
           What could go wrong?
