gnayak
Nov 15, 2022Aspirant
Not able to login to Router web GUI/App after wrong update
Hello, I hope someone can help me with this weird issue. I had a Netgear R7000 router on which I wrongly installed the firmware version EA6900_386.7_2 (the linksys one) . The update was successf...
- Nov 16, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
michaelkenward
Nov 15, 2022Guru - Experienced User
plemans wrote:
I'm betting you started with a 3rd party firmware like ddwrt?
Either that, or they used one of those odd telnet commands (artmtd) that allow you to change the identity of a router. We had to do that when beta testing DumaOS on an R7800 before the hardware was ready.
I doubt if that would help in this case, but it does suggest that your next bit is spot on.
find out what 3rd party firmware you had on the router and post in that forum.
Go visit the place where they cooked up the 3rd party firmware and reverse engineer the process they go through. It sure isn't something that many people here will have experienced.
gnayak
Nov 16, 2022Aspirant
Thanks for the reply guys , I was able to solve it as the linksys firmware needs to be reset while rebooting the router. I did a factory reset changed username and password , and the installed the correct firmware version on the router to fix the issue . been a hassle though 🙂
- FURRYe38Nov 16, 2022Guru - Experienced User
Enjoy. 📡
