jhinkle
Aug 29, 2016Aspirant
Not Able to Port Forward
I've moved a TCP Server application behind my R8000. My Client software attempts to connect using the WAN address associated with my modem. Port Forwarding is set up to pass any TCP/UDP messa...
- Aug 30, 2016
Thanks for reply -- issue resolved.
Turns out Comcast installed a new moden recently and left its modem's firewall active.
Retired_Member
Aug 29, 2016Can or did you test from outside your home network ....Nat loopback is blocked with netgear routers, It's probably working from outside local but cannot be reached from inside.
jhinkle
It's not working from outside, that's why I'm attempting to find out why.
The client is part of a software report package that has been working with my customers for 15 yesrs now.
The only thing I have done is moved my server application from a paid Hostgater server to my own computer behind the R8000 router.
Currently, there is no communication with the outside world.
Any suggestions?
- jhinkleAug 30, 2016Aspirant
