ParSod
Jun 23, 2024Aspirant
Not able to select the 2.4GHz network
I have SSID enabled both for the 2.4GHz and the 5.0GHz networks. Smart connect is disabled. Channel for 2.4 is set to 'auto'. In the past I was able to select both the 2.4 and the 5.0 networks for m...
- Jun 25, 2024
ParSod wrote:Yes, the 2.4GHz led is illuminating.
I have done several factory resets using the reset botton on the back of the router. Pressing it until the font LED's started flashing. This also took me to reinstallation of the router. Everything is back to factory settings including the boxes checked for transmitting both 2.4GHz and 5.0GHz SSID's. Smart Connect is disabled.
Now I have also tried your suggested process pressing the radio on/off switch some times, but still no 2.4GHz SSID transmitted.
Thank you very much for all your support on this issue Kitsap!
At least now you know. Time for a replacement Wi-Fi router.
ParSod
Previously I was able to select either the 5.0 network or the 2.4 network under wifi setting on my computers, iPhone and iPad. Now I only have the 5.0 option. Other external devices which were connected to the 2.4 network have stopped working (weather station, cameras, printer). When trying to reinstall these devices they are not able to find any network. All other devices connected to the 5.0 network works perfectly fine including my Chromecast.
I will try chancing the channel.
Thanks!
ParSod
Jun 24, 2024Aspirant
I have tried changing the channel for the 2.4GHz band, but still not able to see or connect to this band. The 2.4 and 5.0 bands are named individually.
I have also done a factory reset which did not solve the issue. Could it simply be that the router is broken and no longer working on the 2.4 band?
