MJMC's avatar
MJMC
Not connecting to internet- gateway is invalid
I unplugged the modem & router earlier today. When I turned it back on it wouldn't connect to the internet. Netgear genie says the DSL is fine (as does Century Link). I've rebooted the modem both manu...
  • MJMC's avatar
    MJMC
    Apr 07, 2017
    Thanks so much.  With a little help, I finally got it to work.  No idea why it stopped.
    And thanks for the heads up on the model # - I thought I'd put that in.
