MJMC
Apr 06, 2017Aspirant
Not connecting to internet- gateway is invalid
I unplugged the modem & router earlier today. When I turned it back on it wouldn't connect to the internet. Netgear genie says the DSL is fine (as does Century Link). I've rebooted the modem both manu...
- Apr 07, 2017
Thanks so much. With a little help, I finally got it to work. No idea why it stopped.
And thanks for the heads up on the model # - I thought I'd put that in.
MJMC
Apr 07, 2017Aspirant
thanks for the response VE6CGX. When I say novice, I mean true novice. I don't really understand what you said there. 1)how do I run ipconfig? do I even want to change the DNS? 2)how do I ping the gateway 3)what will that tell me?
Thanks!
Thanks!
- michaelkenwardApr 07, 2017Guru - Experienced User
When you have a combination of a modem and router the order in which you start things is important. Here's what Netgear says:
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
You may have to reset the router to make it forget what it discovered if you started things in the wrong order.
You might get better advice if you told people what Netgear hardware you have.
- MJMCApr 07, 2017Aspirant
- michaelkenwardApr 10, 2017Guru - Experienced User
MJMC wrote:And thanks for the heads up on the model # - I thought I'd put that in.
Maybe you did, but the Netgear forum does not share that information with the rest of us.
I thought they had fixed that. Apparently not.
