Matejka111
May 12, 2021Aspirant
Not connecting to internet/ Nighthawk x10 r9000
Help! I’ve had this router for a while now and recently got starlink, so I connected starlink to the router, but now I want to switch back to the old internet. When using the app to setup the router, ...
michaelkenward
May 14, 2021Guru - Experienced User
Matejka111 wrote:
... I don’t want to use the starlink internet anymore.
What is that? A router? A modem/router? Does it have a model number?
What are you trying to do, go back to an old Internet service? A different ISP? Change the hardware you are using?
You need to provide some useful details of your equipment and what you are doing.
You need something to connect your R9000 to the Internet. What do you plan to use?
Matejka111
May 15, 2021Aspirant
I connected the starlink satellite to the net gear router, but I am having problems with starlink so I want to put my old internet back onto the net gear router but when o am setting it up it says wires connected but internet not connecting.
- michaelkenwardMay 16, 2021Guru - Experienced User
Matejka111 wrote:
I connected the starlink satellite ....Sorry. I have no idea what that is. Google isn't much help.
See my earlier questions.
We still don't know how you connect to the Internet. You have to plug the R9000 into whatever does that.
Have you asked you Internet service provider how you should connect a router to its hardware?
