Matejka111
May 12, 2021Aspirant
Not connecting to internet/ Nighthawk x10 r9000
Help! I’ve had this router for a while now and recently got starlink, so I connected starlink to the router, but now I want to switch back to the old internet. When using the app to setup the router, ...
michaelkenward
May 14, 2021Guru - Experienced User
Matejka111 wrote:
... I don’t want to use the starlink internet anymore.
What is that? A router? A modem/router? Does it have a model number?
What are you trying to do, go back to an old Internet service? A different ISP? Change the hardware you are using?
You need to provide some useful details of your equipment and what you are doing.
You need something to connect your R9000 to the Internet. What do you plan to use?
Matejka111
May 15, 2021Aspirant
The internet I an trying to connect to is called Unwired.
- plemansMay 16, 2021Guru - Experienced User
Matejka111 wrote:
The internet I an trying to connect to is called Unwired.Like michaelkenward says, your really not giving us much to go on.
We aren't there to see whats going on so actual model numbers/devices specifics and how you're setting them up help.
