Hamza916
Feb 17, 2021Aspirant
Not working with USB 3.0
So i got the Ac1900 a7000 today and when i plug it into my USB port 2.0 and 3.0 they are both the same speed like I am not seeing a difference in using port 3.0 at all (speed at 866.7 Mbps) and i believe i have all the latest stuff installed so can anyone help me?
What router are you connecting it to?
What speeds do you get over 2.4gh?
Over 5ghz? (2.4ghz is much slower)
How far from the router are you?
what materials is between the router and the A7000.
- Hamza916AspirantI am connecting it to a xfinity router don't know the specific one but it's a good one and my speeds for 5 amd 2.4GHz are the same which is like 866.7 Mbps that's what I was asking why is it not working better on my USB 3.0
- Hamza916AspirantAlso I am noticing that it slows down alot like the wifi will get super slow and sometimes even disconnect any way to fix that. Also I am not too far from the main wifi router maybe 100 feet and the obstacle in the way is a wall.
