Wedosky
Dec 10, 2020Follower
NowTV Broadband Router Reccomendations
Hello,
First thing, apologies if I've posted this in the wrong place. I am posting on here to see recommendations for a router/modem connection to replace my NowTV box.
I currently have a DrayTek 130 and I've tried using a D-Link DIR-882 with no luck. I've followed the instructions for option 60 and 61 (along with getting the correct information from wireshark) with no luck. I figured out this is because the router I used doesn't have support for Opt 60/61 with bridge mode. I've been looking at getting a nighthawk gaming router for a solution, but I'm not sure which would best meet the conditions.
Can anyone suggest a setup (I'd like to avoid combo modem/routers please) that works well with NowTV?
Thanks,
Thanks,
Thanks,
Thanks,
I don't know for other models, but the R7800 with recent firmware has support for options 60 & 61 for DHCP.
I would also suggest contacting your ISP and asking if they have a list of supported devices.
1 Reply
- microchip8Master
