Lostcluster
Apr 12, 2021Aspirant
NTP requests
This is output from the log of the router. The NTP server was set to "netgear" What would cause all of these requests? Looks like it was polling every hour. Thanks for any ideas. [Time synchr...
antinode
Apr 13, 2021Guru
> The router does not know if it's time is correct or not. [...]
Who does? Greater familiarity with "Chicago" song lyrics might yield
some insight.
> [...] It could be wrong the entire time between pollings and it
> wouldn't know. [...]
Sure. So? How much drift are you seeing in an hour? What's your
tolerance?
> [...] What, exactly, is the problem?
Still a mystery.
> [...] I have to assume that it is hardcoded in the firmware. [...]
That's what I'd expect.
> The fact that it did this hourly polling for 3 days and then stopped
> is very strange.
The fact that it _stopped_ is your complaint?
I'd wonder about the completeness of the log, too.
> Short of reflashing the router I am at a loss on how to address.
Does a simple restart change anything? I'm still at a loss regarding
_what_ to address.
> Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Firmware version? Connected to what?
Lostcluster
Apr 13, 2021Aspirant
Firmware is 1.0.2.144
WAN is connected to CM1000 Netgear cable modem
The 2 aggregation ports are connected to 2 ports on GS324T Netgear switch - settings are 802.11ad.
5G radios are combined to single SSD and 2.4G radio is running. No guest network is setup.
I don't care if the time is right, all of my internal devices use my own NTP server. Only the router is getting time from a separate external source. I don't have a complaint per se, but the router is 5 years old and I am wondering if it is just starting to fail. My inquiry was in hopes of finding someone else that has observed this kind of behavior, or feedback from a technical expert as to how the polling frequency is supposed to work and what could make it change since there are no user settings for the parameter.
Personnaly, I doubt that 95% or home users ever look at their logs.
The logs are what they are, when you do a router update the old logs are gone. They appear to be stored in ram.
Thanks for your interest.
