aglaesemann
Apr 26, 2022Aspirant
NTP Settings Refuse to Save
Nighthawk R7000 Firmware Version V1.0.11.134_10.2.119 Did a factory reset after the update. Everything works fine, but NTP settings. Stays on GMT 12 and if I put a custom NTP server...
aglaesemann
Really don't understand why I can't change the drop-down though. Always resets to GMT 12:00 International Date Line.
Even when using Netgear NTP the drop-down refuses to save.
Apr 26, 2022Guru - Experienced User
What browser are you using?
- KitsapApr 26, 2022Master
There are some actions you can take to ensure the firmware update was completed without errors.
Download a fresh copy of the firmware from Netgear.
Perform a firmware default reset. Ensure there are no USB printers, USB hard drives, or USB thumb drives or other devices connected to the router.
Manually re-flash the firmware over an Ethernet connection to the router. Do not use a Wi-Fi connection.
Configure your settings from scratch, do not import a previously saved configuration file.
- FURRYe38Apr 26, 2022Guru - Experienced User
I'm able to set NTP to time zone and custom NTP as well, though my router is not connected to a modem currently:
- aglaesemannApr 26, 2022AspirantI will try another browser. Using Brave.
I just used Safari on Mac. Ms Edge or Firefox should work.
