aglaesemann
Apr 27, 2022Aspirant
NTP Settings Refuse to Save
Nighthawk R7000 Firmware Version V1.0.11.134_10.2.119 Did a factory reset after the update. Everything works fine, but NTP settings. Stays on GMT 12 and if I put a custom NTP server...
aglaesemann
Gives warning:
Warning: The router is failed to connect to NTP server, please check your Internet connectivity or try another NTP server
but the drop-down still reverts to GMT 12.
Hmm, only PC I have. Couldn't find how to switch it through the app.
GregGreg
May 03, 2022Star
aglaesemann
I have similar problem in previous firmware version.
Currently, to minimize router problems, I reset the settings to default before each upgrade. After a upgrade, I also reset the settings to default and set everything again.
Below my settings (working properly):
tempus1.gum.gov.pl - is Poland government time server.
Try to reset router
Set NTP with properly name of NTP server
It worked for me.
- aglaesemannMay 16, 2022Aspirant
what browser did you use?
- aglaesemannMay 17, 2022Aspirant
Wondering if this is some Malware foothold or possibly my router starting to fail.
Weird that it won't hold any NTP setting (Even tried your settings for fun, but reverted upon save.).
It's odd that NTP is only setting having issues and after a few weeks it starts to query the Pool time servers like crazy. Talking 500+ an hour. Weird.
