aglaesemann
Apr 27, 2022Aspirant
NTP Settings Refuse to Save
Nighthawk R7000 Firmware Version V1.0.11.134_10.2.119 Did a factory reset after the update. Everything works fine, but NTP settings. Stays on GMT 12 and if I put a custom NTP server...
GregGreg
May 03, 2022Star
aglaesemann
I have similar problem in previous firmware version.
Currently, to minimize router problems, I reset the settings to default before each upgrade. After a upgrade, I also reset the settings to default and set everything again.
Below my settings (working properly):
tempus1.gum.gov.pl - is Poland government time server.
Try to reset router
Set NTP with properly name of NTP server
It worked for me.
aglaesemann
May 16, 2022Aspirant
what browser did you use?
