TomBlack
Dec 31, 2021Guide
NTP Time Broke
V1.0.11.128_10.2.112 NTP set to GMT -5. When the Router sends a log file, the time is off by 5 hours. The email is time stamped: [email sent to: Tom.Black@Comcast.net] Thursday, Dec 30,20...
TomBlack
Dec 31, 2021Guide
I updated Firmware from R7000-V1.0.9.88_10.2.88. Had no NTP issues with this Firmware. NTP issue started with the latest Firmware previously noted V1.0.11.128_10.2.112.
The R7000 Router shows the correct time on the NTP screen and is repeatable even after a Router Reboot. It's the Send Email Function that is NOT reading the NTP time correctly. It's showing GMT instead of GMT -5 that is set in the Router NTP Screen.
Dec 31, 2021Guru - Experienced User
Since I was tagged, not a clue :)
I rarely setup any logging with emailed responses and I don't have that specific device to test it on.
Sorry.
