negh_var
Jan 09, 2022Aspirant
NTP timezone on R7000P not accepted
Has anyone ever gotten a satisfactory response from Netgear on the NTP settings bug for the Netgear routers? I'm constantly having issues with my router and I can't help but shake the feeling that t...
Jan 09, 2022Guru - Experienced User
What browser are you using?
negh_var
I'm patched with my router into an NBN FTTP NTD.
I'm using Microsoft Edge (Chromium) but also tried with Opera.
Yes have done factory resets since the last firmware update.
- FURRYe38Jan 09, 2022Guru - Experienced User
Curious if you disconnected the router from the ISP NTD device, can you change the NTP configuration at all?
Wonder if you revert back to last working version if it resolves?
- michaelkenwardJan 10, 2022Guru - Experienced User
That's describes the technology, not the hardware make and model.
Network Termination Device (NBN) - Wikipedia
Simple ethernet output?
- KitsapJan 10, 2022Master
What NTP server are you attempting to connect to??
If you are using the Netgear default, your results may vary.
A good option is to use pool.ntp.org.
You can get some background via your web browser search box.
