aeperkins63
Jul 27, 2022Guide
Number 6 by my wifi signal
There's a number 6 right by my wifi signal and am wondering what it means. Contacted Samsung, they didn't have a clue so I'm asking netgear since it might mean wifi 6 is what I'm receiving on ny smart...
aeperkins63
Jul 27, 2022Guide
Even better pic of number by my wifi signal strength.
Jul 27, 2022Guru - Experienced User
Does the number change any if you walk away from the host wifi router?
Something the phone mfr should know. UI Indications seen on mobile devices come from the phone mfr.
- aeperkins63Jul 27, 2022Guide
So, the 6 next to my router signal strength means what???
- plemansJul 28, 2022Guru - Experienced User
So there's wifi 6 and wifi 6e.
The wifi 6 is 2.4ghz and 5ghz.
wifi 6e is 2.4ghz, 5ghz, and 6ghz.
- aeperkins63Jul 27, 2022GuideYes. Of course a stores wifi, mostly free, has no numbers at all with their wifi signal. Only at home am I getting the num 6 next to signal strength. Has to be the wifi 6 coming from the router itself I guess??
- FURRYe38Jul 27, 2022Guru - Experienced User
Maybe there is some signal quality that maybe seen with the phone and your router vs a different router that doesn't have any additional information for the phone to use. Also if your on a guest network wifi, this may not be available either. Something the phone mfr should know of as they design the UI for the phone and the components of it. They tell the phone what to display and in case of extra features maybe available on some wifi signals, can display this number.
- aeperkins63Jul 27, 2022GuideThey acted like they had no clue. Maybe I was talking to the wrong person. So I should try the manufacturer again or find some techno wizard to confer with?
