aeperkins63
Jul 27, 2022Guide
Number 6 by my wifi signal
There's a number 6 right by my wifi signal and am wondering what it means. Contacted Samsung, they didn't have a clue so I'm asking netgear since it might mean wifi 6 is what I'm receiving on ny smart...
Jul 27, 2022Guru - Experienced User
Does the number change any if you walk away from the host wifi router?
Something the phone mfr should know. UI Indications seen on mobile devices come from the phone mfr.
aeperkins63
Jul 27, 2022Guide
So, the 6 next to my router signal strength means what???
- plemansJul 28, 2022Guru - Experienced User
So there's wifi 6 and wifi 6e.
The wifi 6 is 2.4ghz and 5ghz.
wifi 6e is 2.4ghz, 5ghz, and 6ghz.
