aeperkins63
Jul 27, 2022Guide
Number 6 by my wifi signal
There's a number 6 right by my wifi signal and am wondering what it means. Contacted Samsung, they didn't have a clue so I'm asking netgear since it might mean wifi 6 is what I'm receiving on ny smart...
Jul 27, 2022Guru - Experienced User
Maybe there is some signal quality that maybe seen with the phone and your router vs a different router that doesn't have any additional information for the phone to use. Also if your on a guest network wifi, this may not be available either. Something the phone mfr should know of as they design the UI for the phone and the components of it. They tell the phone what to display and in case of extra features maybe available on some wifi signals, can display this number.
aeperkins63
Jul 27, 2022Guide
They acted like they had no clue. Maybe I was talking to the wrong person. So I should try the manufacturer again or find some techno wizard to confer with?
- FURRYe38Jul 27, 2022Guru - Experienced User
Ya most 1st level tech support may not be very knowledgable. Ya see if you can find more experienced tech support or find there tech support forum and post this there. Might find other users with this device seeing same thing.
- aeperkins63Jul 27, 2022GuideThank you sir, a pleasure and a learning experience non the less. Stay safe, you and family!
Good Luck and enjoy. đ
