IrvSp
Nov 28, 2017Master
Odd problems with an R7000
I've found a few problems. On the V1.0.9.12_1.2.23 right now, and was on it when I discovered a 'problem'. I backtracked to V1.0.9.10 and discovered another problem. The 'new' problem i...
- Dec 04, 2017
JamesGL, I finally got the ISP to see it was somewhere on their side. Had to remove the router and use just the modem and the problem was still there. Lease time only 2 hours or less.
On a related note I see the latest flash has a fix for when it renews a lease.
- Fixes the issue where Internet sessions are disconnected when the DHCP lease update occurs on the Internet port.
It was probably that that made me notice I had a problem since it was happening every hour or so and sometimes browsing hung for a short period or reported a connection was broken?
JamesGL
Dec 03, 2017NETGEAR Employee Retired
Hi IrvSp,
Is your post from the other thread confirming that the issue is not with the router, related to this thread?
IrvSp
Dec 04, 2017Master
